HP iPAQ Pocket PC h1900 Series - Product Specifications
System specifications
Not all models described are available in all regions.
System feature
Processor
HP iPAQ Pocket PC h1940 models: Samsung S3C2410 266 MHz
HP iPAQ Pocket PC h1930 models: Samsung S3C2410 203 MHz
HP iPAQ Pocket PC h1910 models: Intel PXA 250 (200 MHz)
HP iPAQ Pocket PC h1915 and h1920 models: Intel PXA 255 (200 MHz)
Random Access Memory (RAM)
64 MB SDRAM (56 MB main memory)
HP iPAQ Pocket PC h1935 models (56 MB main memory)
HP iPAQ Pocket PC h1930, h1937, h1940, and h1945 models (56 MB main memory)
HP iPAQ file store (nonvolatile memory)
HP iPAQ Pocket PC h1940, and h1945 models: 14 MB storage (not available in Korean, Japanese, Traditional Chinese, and Simplified Chinese versions)
SD I/O slot
SD memory and SDIO card support
3.5-inch transflective color TFT, 240 x 320 pixels, 64K-color support.
LED backlight
Multi-level brightness adjustment
Audio
Microphone, speaker, 2.5 mm stereo audio jack, MP3 stereo through audio jack
Infrared (IrDA)
IrDA, data transfer up to 115.2 Kb per second
Bluetooth (HP iPAQ Pocket PC h1940 and h1945 only)
Class II device; typical 10 meters (30 feet) range
Indicators
3-mode alarm notification: flashing green LED, tone, pop-up message
Charging: flashing amber LED
Charged: solid amber LED
Bluetooth active: flashing blue LED
Battery
Removable/rechargeable 900 mAh Lithium ion battery with internal backup battery to maintain data during main battery replacement
Physical specifications
Attribute
Measurement (US)
Length
113.3 mm (4.46 inches)
Width
69.8 mm (2.75 inches)
Depth
12.8 mm (0.50 inches)
124 g (4.37 ounces)
Operating environment
Environment
Operating/Non-Operating
Range
Temperature
Operating
0 to 40 degrees C (32 to 104 degrees F)
Nonoperating
-20 to 60 degrees C (-4 to 140 degrees F)
Relative humidity
Operating
Up to 80 percent
Nonoperating
Up to 80 percent
Maximum altitude
Operating
0-4572 m (0-15,000 feet)
Nonoperating
