    Windows 11 Upgrade Guide
HP Photosmart Series Printers - How To Print Internal Tests
This document explains how to perform built-in internal tests on specific HP Photosmart series printers.
The internal tests can be used to verify that the printer internal firmware is functioning properly.
The tests do not verify that the computer and printer connections are working properly.
It is always preferable to perform all these tests when the communication cable has been disconnected from the printer, and after having turned off and on the printer.
HP Photosmart 100 and 130 series printers
  1. Ensure that the memory card has been removed from the memory card slot.
  2. Make sure 10 x 15 cm paper is loaded in the In Tray.
  3. On the control panel, press and hold the Print button until the printer begins to print a test page.
HP Photosmart 140 series printers
  2. Make sure 10 x 15 cm paper is loaded in the paper In Tray.
  3. On the control panel, press the Left/Right Select Photo button to highlight Print Test Page.
  4. Press the OK button.
HP Photosmart 230 series printers
  3. Press the Menu button.
  4. Scroll up (use the Up/Down arrow button) to highlight Print Test Page.
  5. Press the OK button.
HP Photosmart 245, 375, and 385 series printers
  4. Press the Up/Down arrow button to display the Tools menu. Then press the OK button.
  5. Press the Up/Down arrow button to highlight Print Test Page.
  6. Press the OK button.
HP Photosmart 325 and 335 series printers
  3. Press the Left/Right Select Photo button to highlight the Tools menu and then press the OK button.
  4. Press the Left/Right Select Photo button to highlight Print Test Page.
HP Photosmart 420 series printers
  1. Place the camera onto the docking connector. If the printer does not turn on automatically, turn on the printer.
  3. Press the OK button to display the camera menus.
  4. Press the Up/Down arrow button to highlight Print Test Page.
  6. When prompted to insert plain paper, press the OK button again.
HP Photosmart 470 series printers
  5. Press the Up/Down arrow button to highlight Print a Test Page.
HP Photosmart 1000, 1100, and 1115 series printers
  2. Make sure plain paper is loaded in the In Tray.
  3. On the control panel, press the Right arrow in the Tools button until Print a Test Page? is displayed.
  4. Press the OK/Yes button.
HP Photosmart 1215, 1218, and 7600 series printers
  3. On the control panel, press the Right arrow in the Menu button until Print a Test Page? is displayed.
HP Photosmart 1315 series printers
  4. Press the Up/Down arrow button to highlight Print a Test Page. Then press the tick symbol button.
HP Photosmart 7150 series printers
  1. Make sure plain paper is loaded in the In Tray.
  2. Press and hold the Power button.
  3. Press the Resume button four times.
  4. Release the Power button.
HP Photosmart 7200 and 7400 series printers
  3. Press the Save button four times.
HP Photosmart 7350 series printers
  3. On the control panel, press the Right/Left arrow button in the Tools button several times until Print a Test Page? is displayed.
HP Photosmart 7550, 7700, 7960, 8150 and 8450 series printers
  5. Press the Down arrow button to highlight Print a Test Page. Then press the OK button.
HP Photosmart 7850 series printers
  2. Press and hold the Select button.
  3. Press the Left arrow button once.
  4. Release the Select button.
HP Photosmart 8050 and 8250 series printers
HP Photosmart 8750 professional series printers
  2. Press the Menu button on the printer control panel.
  3. Press the Right arrow button six times.
  4. Confirm the display says Print a test page.
  5. Press the Select Photo button on the control panel to print the test page.
HP Photosmart A300 series
  1. Make sure the printer is turned on.
  2. Load paper in the input tray. Use plain paper or index cards to conserve photo paper.
  3. Press and hold down the OK button.
  4. Press the On button two times to print a test page.
HP Photosmart A400 series
The camera must be in the camera dock on the printer in order to print a self test.
  2. Dock the camera on the printer. (Turn on the camera manually if it does not turn on automatically. The Camera LCD acts as the LCD for the Printer when docked.)
  3. Load paper in the input tray. Use plain paper or index cards to conserve photo paper.
  4. Press the Menu/OK button on the printer.
  5. Press the Left/Right arrow button to highlight Settings.
  6. Press the Up/Down arrow button to highlight Tools.
  7. Press the Menu/OK button on the printer.
  8. Press the Up/Down arrow button to highlight Print Test Page.
  9. Press the Menu/OK button on the printer to begin printing the test page.
HP Photosmart A500 series
  2. Make sure the printer is turned on.
  4. Press the Left/Right arrow button to open the printer menu.
  5. Press the Left/Right arrow button to highlight Tools. Press the OK button.
  6. Press the Left/Right arrow button to highlight Print Test Page. Press the OK button.
HP Photosmart A600 series
  4. Press the Menu button to open the printer menu.
  5. Press the Up/Down arrow button to highlight Tools. Press the OK button.
  6. Press the Up/Down arrow button to highlight Print Test Page.
  7. Press the OK button to begin printing the test page.
HP Photosmart A700 Series
HP Photosmart D5000 Series
  3. Make sure plain paper is loaded in the In Main Tray.
  4. Press and hold the OK button.
  5. Press and release the Left arrow button once. The printer display shows 10 briefly.
  6. Release the OK button to print the Test Page.
HP Photosmart D5100 Series
  3. Make sure the CD tray is closed.
  4. Make sure plain paper is loaded in the In Main Tray.
  5. Press and hold the OK button.
  6. Press and release the Left arrow button once. The printer display shows 10 briefly.
  7. Release the OK button to print the Test Page.
HP Photosmart D7100 Series
  3. Make sure plain paper is loaded in the In Tray.
  4. Press the Home button to access the Home screen.
  5. Press the Left/Right arrow button to highlight Settings. Then press the OK button.
  6. Press the Up/Down arrow button to display the Tools menu. Then press the OK button.
  7. Press the Up/Down arrow button to highlight Print Test Page.
  8. Press the OK button to begin printing the test page.
HP Photosmart D7300 Series
  4. Touch the home icon in the upper left-hand corner to access the home screen.
  5. Touch Settings on the screen.
  6. Touch Tools on the screen.
  7. Touch the Up/Down arrow on the right of the screen to scroll for more options.
  8. Touch Print Test Page to begin printing the test page.
