HP Workstation xw4100 PC Product Specifications
Product image
Product features
Feature
Specification
3Q03 Refresh
Processor
Intel Pentium 4 processor
  • 2.4 GHz (533-MHz system bus)
  • 2.6 GHz (800-MHz system bus)
  • 2.8 GHz (800-MHz system bus)
  • 3.0 GHz (800-MHz system bus)
3.2GHz 800MHz FSB, Hyper-Threading capable
Intel 875P chipset
Chassis
Next generation convertible mini-tower chassis
Cache
512-KB integrated, full speed Level 2 cache per processor
Memory
  • 4 GB Maximum of dual-channel PC3200 DDR-400 or PC2700 DDR-333 when 1 GB PC3200 DIMMs become available
  • 4 DIMM slots (6.4 GB/s and 5.4 GB/s throughput respectively)
1GB DDR 333 (PC2700) ECC SDRAM modules
Network
Integrated Broadcom Gbit LAN 10/100/1000Mbs Network Interface
Slots
  • I/O (Total) - 6 total slots available
  • PCI - 32-bit/33 MHz - 5 slots available
  • AGP 8X - 1 slot available
Drive Bays
  • (Total/Available) - 6 total / 3 available
  • Internal - 2, 3.5-inch bays / 1 available
  • External - 3 external 5.25-inch bays / 2 available (third external bay is not full depth in MT orientation)
  • 1 external 3.5-inch diskette drive (optional)
USB Support
6 USB 2.0 ports (2 front, 4 rear)
I/O
  • Parallel - 1 25-pin port (rear)
  • USB - 6 USB 2.0 ports (2 front, 4 rear)
  • Serial - 1 9-pin connectors (rear), (2nd port optional)
  • Ultra160 SCSI (optional) - internal and external (rear) connectors
  • Ultra320 SCSI (optional) - internal and external (rear) connectors
  • Ultra ATA/100 - 2 connectors (internal)
  • Keyboard - 1 PS/2 keyboard port (rear)
  • Pointing Device - 1 PS/2 mouse port (rear)
  • Network interface - 1 RJ-45 connector (rear)
  • Microphone Jack - 1 (front)
  • Headphone Jack - 1 (front)
  • Line-In Jack - 1 (rear)
  • Line-Out Jack - 1 (rear)
  • IEEE 1394 / Firewire (optional) - 3 connectors (1 front, 2 rear)
NOTE:  The ICH5 supports Serial ATA (SATA)
The ICH5 supports Serial ATA (SATA), and there are two SATA 150 ports on the HP Workstation xw4100 system board. However, SATA devices are not supported at product launch. There will be a separate announcement if SATA support is added at a later date.
Diskette Drives
1.44-MB
Optical Storage
  • CD-ROM
  • CD-RW
  • DVDROM
  • CD-RW/DVD-ROM combination
  • DVD+RW/+R, or no optical disk
Hard Drives
  • 40-, 80-, or 250-GB Ultra ATA (7200 rpm)
  • 80-, 160-, or 250-GB Serial ATA (7200 rpm)
  • 36-, 73-, or 146-GB Ultra320 SCSI (10,000 rpm)
  • 36- or 73-GB Ultra320 SCSI (15,000 rpm)
Keyboard
HP Easy Access Keyboard
Mouse
HP scroll mouse
Graphics (One of the following:)
  • NVIDIA Entry 2D Graphics
  • NVIDIA Quadro NVS 200
  • NVIDIA Quadro NVS 280
  • NVIDIA Quadro NVS 400
  • NVIDIA Quadro4 380 XGL
  • ATI FireGL T2-128
  • NVIDIA Quadro4 980 XGL
High-end 3D
  • NVIDIA Quadro FX 2000
Audio
AC97/16-bit stereo full-duplex
Operating Systems
  • Microsoft Windows XP Professional preinstall – Service Pack 1
  • Microsoft Windows 2000 Professional preinstall – Service Pack 3
  • Red Hat Linux 7.3 preinstalled
  • HP Installer Kit for Linux (supports custom installations of Red Hat 7.3, 9.0 and Enterprise Workstation Edition 3.0) (7.2 support will be added in Early 2004)
Management
System Software Manager
Insight Management Agent
Altiris Express
Asset Control
Alert on LAN (AoL)
Wake on LAN (WoL)
Fault Management
Security Management
Pre-Failure Warranty (hard drives and memory)
Remote Management
  • Remote Wakeup
  • Remote ROM Flash
  • Remote Security
  • Remote Shut Down
BIOS Features
  • Advanced Configuration and Power Interface (ACPI) 1.0b
  • Advanced Power Management (APM) 1.2
  • Desktop Management Interface (DMI) 2.0
  • System Management (SM) BIOS 2.3
Security
  • Diskette write and boot control
  • Flash ROM lock
  • Keyboard password
  • Network server mode
  • Parallel interface control
  • Power-on password
  • Serial interface control
  • Setup password
  • Cable lock provision
  • Solenoid Hood Lock / Sensor (optional)
Power Supply
280 W
Protected by HP Services including a three-year, limited warranty with three-year parts coverage, three year, on-site service, and three-year labor (in many countries); 7 x 24 hardware technical phone support and on-line support through the Internet; Pre-Failure Warranty coverage of hard drives, memory, and processors.
NOTE:  Certain restrictions and exclusions apply
Certain restrictions and exclusions apply. Consult the customer support center for details.
Three-year, onsite and labor not available in all countries.
System specifications
Physical characteristics
U.S.
Metric
Tower dimensions (H x W x D)
17.7 in. x 6.6 in. x 17.9 in.
45.0 cm x 16.8 cm x 45.6 cm
Weight (standard configuration)
35 lbs.
16 kg.
Power supply
Rated line frequency
50 to 60 Hz
Rated input current
  • 3.6 A @ 115 VAC
  • 1.8 A @ 230 VAC
Maximum rated power
  • 412 W input
  • 280 W output
Temperature
Operating
10 degrees to 35 degreesC / 50 degrees to 95 degrees F
Non-operating
-30 degrees to 60 degreesC / -22 degrees to 140 degrees F
Humidity (non-condensing)
Operating
15 percent to 80 percent
Non-operating
10 percent to 90 percent
Maximum altitude (nonpressurized)
Operating
3,048 m / 10,000 ft
Non-operating
4,572 m / 15,000 ft
