    Fix and resolve Windows 10 update issue on HP Computer or Printer. Click here
HP Pavilion x360 14-dh0022tu Product Specifications
6QX87PA
Intel® Pentium® Silver N5000 (1.1 GHz base frequency, up to 2.7 GHz burst frequency, 4 MB cache, 4 cores)
Intel® Integrated SoC
4 GB DDR4-2400 SDRAM (1 x 4 GB)
Video graphics
Intel® UHD Graphics 605
128 GB M.2 SSD
Optical drive
Optical drive not included
14" diagonal HD SVA micro-edge WLED-backlit touch screen (1366 x 768)
802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 combo
1 USB 3.1 Gen 1 Type-C™ (Data Transfer Only, 5 Gb/s signaling rate); 2 USB 3.1 Gen 1 Type-A (Data Transfer Only); 1 AC smart pin; 1 HDMI; 1 headphone/microphone combo;
32.4 x 22.29 x 2.05 cm
Starting at 1.59 kg
45 W AC power adapter
3-cell, 41 Wh Li-ion
HP 3D DriveGuard; HP Audio Switch; HP CoolSense; HP Documentation; HP JumpStart; HP Support Assistant; HP Connection Optimizer; HP Privacy Settings
Country/Region: Flag Australia
