HP Support
HP LaserJet Products - Products Supported in Windows 7
This document lists the HP products that are currently supported in the Windows 7 operating system. All HP products released after the Windows 7 release date will be supported.
For descriptions of the various Windows 7 drivers, see Descriptions of Windows 7 drivers at the end of this document.
Supported products
Review the following sections to determine if your product is supported by Windows 7, and also driver availability for your product.
HP LaserJet Printers
  • HP HotSpot LaserJet Pro M1218nfs series: Full Solution Driver, In-OS driver
  • HP LaserJet 1018 series: Host Based Plug and Play Driver
  • HP LaserJet 1020 printer: Host Based Plug and Play Driver
  • HP LaserJet 1020 Plus printer: Full Solution Driver and Host Based Plug and Play Driver
  • HP LaserJet 1022 series: Host Based Plug and Play Driver
  • HP LaserJet P1005 Limited series: Full Solution CD, Full Solution Driver, and Host Based Plug and Play Driver
  • HP LaserJet P1006 series: Full Solution CD, Full Solution Driver, and Host Based Plug and Play Driver
  • HP LaserJet P1007 series: Full Solution Driver and Host Based Plug and Play Driver
  • HP LaserJet P1008 series: Full Solution Driver and Host Based Plug and Play Driver
  • HP LaserJet P1009 series: Host Based Plug and Play Driver
  • HP LaserJet P1500 series: Full Solution CD, Full Solution Driver, and Host Based Plug and Play Driver
  • HP LaserJet Pro P1102w Printer: Full Solution CD, Full Solution Driver, and Host Based Basic Driver
  • HP LaserJet Pro P1566 Printer: Full Solution CD, Full Solution Driver, and Host Based Basic Driver
  • HP LaserJet Pro P1606dn Printer: Full Solution CD, Full Solution Driver, and Host Based Basic Driver
HP Color LaserJet Printers
  • HP Color LaserJet CP1210 series: Full Solution CD, Full Solution Driver, and Host Based Plug and Play Driver
  • HP Color LaserJet CP1510 series: In-OS Driver and Universal Print Driver
HP LaserJet Multifunction Printers
  • HP Color LaserJet Pro M176n Multifunction Printer: Full Solution CD, Full Solution Driver
  • HP Color LaserJet Pro M177fw Multifunction Printer: Full Solution CD, Full Solution Driver
  • HP Color LaserJet M252dw Printer: Full Solution CD, Full Solution Driver
  • HP Color LaserJet M252n Printer: Full Solution CD, Full Solution Driver
  • HP Color LaserJet Pro MFP M277dw Printer: Full Solution CD, Full Solution Driver
  • HP Color LaserJet Pro MFP M277n Printer: Full Solution CD, Full Solution Driver
  • HP LaserJet Pro 200 Color M251 Printer Series: Full Solution CD and Full Solution Driver
  • HP LaserJet Pro 200 Color M276 Printer Series: Full Solution CD and Full Solution Driver
  • HP LaserJet M1120 Multifunction Printer series: Full Solution Driver and Host Based Plug and Play Driver
  • HP LaserJet Pro M1130 Multifunction Printer series: Full Solution CD and Full Solution Driver
  • HP LaserJet Pro M1210 Multifunction Printer series: Full Solution CD and Full Solution Driver
  • HP LaserJet Pro MFP M125 Printer series: Full Solution CD, Full Solution Driver
  • HP LaserJet Pro MFP M126 Printer series: Full Solution CD, Full Solution Driver
  • HP LaserJet Pro MFP M127fn Printer: Full Solution CD, Full Solution Driver
  • HP LaserJet Pro MFP M127fw Printer: Full Solution CD, Full Solution Driver
  • HP LaserJet Pro MFP M201dw Printer: Full Solution CD, Full Solution Driver
  • HP LaserJet Pro MFP M201n Printer: Full Solution CD, Full Solution Driver
  • HP LaserJet Pro MFP M202dw Printer: Full Solution CD, Full Solution Driver
  • HP LaserJet Pro MFP M202n Printer: Full Solution CD, Full Solution Driver
  • HP LaserJet Pro MFP M225dn Printer: Full Solution CD, Full Solution Driver
  • HP LaserJet Pro MFP M225dw Printer: Full Solution CD, Full Solution Driver
  • HP LaserJet Pro MFP M226dn Printer: Full Solution CD, Full Solution Driver
  • HP LaserJet Pro MFP M226dw Printer: Full Solution CD, Full Solution Driver
  • HP LaserJet M1319 Multifunction Printer series: Full Solution Driver and Host Based Plug and Play Driver
  • HP LaserJet Pro MFP M176n Printer series: Full Solution CD, Full Solution Driver
  • HP LaserJet Pro MFP M177fw Printer series: Full Solution CD, Full Solution Driver
The following sections describe the drivers available for Windows 7.
Full solution CD
This installation provides full product functionality and includes valuable software to help you get the most out of your product.
Full solution driver
This driver provides full product functionality and does not require additional HP software.
Host Based driver
This driver uses your computer's resources to process print jobs, taking advantage of the computer's memory and processing power.
Host Based Plug and Play driver
This driver provides EZInstall to assist with installation for direct USB connections and provides basic printing functionality. It uses your computer's resources to process print jobs, taking advantage of the computer's memory and processing power.
In-OS driver
A full feature software and driver package for Windows 7 is not available for your product. However, the Windows 7 operating system installed on your computer contains a basic driver solution for your product. With the basic driver, some of the advanced product features are not available. You can print from a software program, and import and view images on a memory card, if your product has a memory card slot. With this basic driver, the buttons on the product do not function and some of the advanced product features are not available.
This driver works with a broad range of networked and direct-connected HP products, and is designed to simplify the task of managing multiple devices with the use of a single driver.
Prefer to troubleshoot on your own?
Consumer Community
Consumer Community
Join the conversation! Find Solutions, ask questions, and share advice with other HP product owners. Visit now >
Enterprise Business Community
Join HP's community of business and IT professionals to help solve problems, exchange ideas, and learn best practices from your peers. Worldwide discussions in English. Visit now >
Country: Vietnam
