HP Customer Support
HP Printers - Removing HP Smart Print from the IE Toolbar
HP Smart Print is no longer available for download from HP and is not compatible with Internet Explorer 9 and later versions.
Remove HP Smart Print by uninstalling it from the Internet Explorer toolbar.
  1. In Internet Explorer, right-click within the toolbar area.
    The toolbar menu displays.
  2. In the menu, hover over Customize, and then click Add or remove commands.
    Figure : Click Add or remove commands
    Image: Click Add or remove commands
  3. In the Customize Toolbar menu, select HP Smart Print, click Remove, and then click Close.
    Figure : Customize Toolbar menu
    Image: Customize Toolbar menu
    The HP Smart Print icon no longer displays in the Command bar.
Country: Flag Vietnam
