This document explains the flow of steps when you select Diagnose your printer in the Samsung Printer Diagnostics (SPD) application.
note:If there is no installed printer driver, the Install printer driver screen will display. If the printer you want is not connected, you can select it from the list and then click The printer that I want isn't listed. Add a printer.Figure : Select the printer to connectA screen opens where you choose how to connect your printer.Figure : Choose how to connect the printer
