Figure : Illustration of the Elite Slice G2
The Elite Slice G2 features Bang & Olufsen audio and wireless communication for Intel Unite or Microsoft Skype Room System (SRS) conferencing software. Four speakers are on the Elite Slice G2, one in each corner and four microphones are on the top.
Top components
The Elite Slice G2 top components enable call control with capacitive touch buttons for conference calls.
Figure : Identifying the top capacitive touch buttons
Item
Component
Item
Component
1
Answer/Call
4
Volume up
2
Mute
5
Reject/Disconnect call
3
Volume down
Rear components
Figure : Identifying the Elite Slice G2 rear components
Item
Component
Item
Component
1
Power button
5
USB ports (2)
2
Power jack
6
Dual-Mode DisplayPort (D++) port
3
RJ-45 (network) jack
7
HDMI port
4
USB type C port with Alt Mode
8
Security cable slot
Side components
Figure : Identifying the Elite Slice G2 side components
Item
Component
Item
Component
1
USB Type-C port
(disabled from factory, enabled through system BIOS)
2
Audio-out (headphone)/Audio-in (microphone) combo jack
