HP Customer Support
HP Tablets - Finding the Model Number, Product Number, Serial Number, and Android OS Version (Android KitKat, Jelly Bean)
This document applies to HP and Compaq tablets with Android 4.4/KitKat and 4.2/Jelly Bean operating systems.
Use this document to find the product and system information you might need for obtaining warranty information, service, or updates on your HP tablet.
Depending on the version of Android installed on your tablet, some of the images in this document may not match your tablet exactly.
Finding the HP tablet model number, product number, and serial number
The model number, product number, and serial number are located in one or more of the following places on your tablet:
  • The serial number and product number are laser-etched on the side, top, or bottom edge of the tablet.
    Figure : Serial number and product number location on edge of tablet
    Figure : Laser-etched serial number (S/N) and product number (P/N)
  • The model number and serial number (SN) are displayed on a label affixed to the back of the tablet.
      Figure : Label on back of tablet showing model number and serial number (example)
    1. Model number
    2. Serial number
  • The model number, serial number, and product number are printed on a service label affixed to the tablet packaging.
      Figure : Service label on packaging (example)
    1. Model number
    2. Serial number
    3. Product number
  • The serial number can be found in the About tablet section of the Settings menu, using the following steps:
    1. On the Home screen, tap the All apps icon, and then tap the Settings icon.
    2. In the System section, tap About tablet.
      Figure : About tablet
      About tablet
    3. Tap Status.
      Figure : Status
      Status
    4. Locate the Serial number listing.
      Serial number
Finding the Android operating system (OS) version on your HP tablet
Use the following steps to find the Android OS version on your tablet:
    About tablet
  3. See the information under Android version for the OS version installed on your tablet.
    Figure : Android version
    Android version
Country: Flag Serbia
