HP Customer Support
HP Printers - How Do I Find My Model or Printer Number?
This document is for HP inkjet and LaserJet printers.
This document describes how to find the model number of your printer. A model number is a unique numeric or alphanumeric code used to identify a particular version of a printer. There are different areas on the body of a printer where model numbers are commonly located. Look for the printer model number in one area, and then check another area if you do not find the model number.
The same series of a printer might have several different models with varying features. The printers pictured below are examples, and while your printer might look different, the areas where model numbers might be located should be applicable.
The following are example model numbers that might look similar to the model number on your printer:
  • HP Deskjet 1515 Printer
  • HP ENVY 4530 All in One Printer
  • HP LaserJet M1120 Multifunction Printer
  • HP Officejet 4610 All in One Printer
  • HP Officejet 6500a Plus All-in-One Printer
Do not confuse the model number (for example, HP LaserJet M1120) with the part number (for example, Q1234), which is used to order printer parts.
Watch a short video to learn how to find the model number, product number, and serial number for your product.
If you have trouble viewing the video, or to view the video in a different size, click here to play the video on YouTube.
Common model number locations
Look in the following areas to find the model number for your printer. If you are unable to find the model number using the examples in this section, continue to the next section.
Model number location
Printer example and details
On the control panel, under the display
Model number on the control panel (control panel location varies)
Locate the model number under the display on the control panel. The control panel location varies.
Near the ink cartridges
Example model number location (near the ink cartridges)
On some printer models, the model name and model number are in separate locations. The model name, such as HP Officejet Pro 8000, can be found in another location listed in this document. The specific model number, such as A809a, is located near the ink cartridges or inside the ink cartridge door. You might need to open the ink cartridge door to view the model number.
Locate the model number on the top of the printer
Review the following table to identify possible model number locations, and then compare them with your printer. If you are unable to find the model number using the examples in this section, continue to the next section.
Printer example
Upper-right corner (top)
Model number on the top of the product, in the upper-right corner
Lower-right corner (top)
Model number on the top of the product, in the lower-right corner
Upper-left corner (top)
Model number on the top of the product, in the upper-left corner
Lower-left corner (top)
Model number on the top of the product, in the lower-left corner
Locate the model number on the front of the printer
Printer example
Upper-right corner (front)
Model number on the front of the product, in the upper-right corner
Lower-right corner (front)
Model number on the front of the product, in the lower-right corner
Upper-left corner (front)
Model number on the front of the product, in the upper-left corner
Lower-left corner (front)
Model number on the front of the product, in the lower-left corner
Lower-middle (front)
Model number on the front of the product, in the lower middle
Upper-middle (front)
Model number on the front of the product, in the upper middle
Upper-middle (front), under the top cover
Model number on the front of the product, in the upper middle, under the top cover
Middle-left (front)
Model number on the front of the product, in the middle-left
Middle, on the front panel
Model number on the front panel of the product, in the middle
Country: Flag Serbia
