Pomoc techniczna HP dla klientów
Działania
Trwa ładowanie...
Działania
Trwa ładowanie...
Działania
Trwa ładowanie...
Printer Specifications for HP Deskjet F2400 All-in-One Printer Series
Rys. : HP Deskjet F2400 All-in-One Printer Series
Picture of the product.
HP Deskjet F2400 All-in-One Series models
Printer model
Part Number
HP Deskjet F2420 All-in-One
CB735A
CB735B
HP Deskjet F2423 All-in-One
CB735C
HP Deskjet F2430 All-in-One
CB743A
HP Deskjet F2476 All-in-One
CB731A
HP Deskjet F2480 All-in-One
CB730A
CB730B
HP Deskjet F2483 All-in-One
CB730C
HP Deskjet F2488 All-in-One
CB730D
HP Deskjet F2492 All-in-One
CB733B
HP Deskjet F2493 All-in-One
CB733C
System requirements
Review the following tables for system requirements.
Windows
Feature
Minimum system requirements
Windows XP Home, XP Professional, XP Media Center Edition, and Tablet PC Edition (SP2 or later)
Processor
Any Intel® Pentium® II, Celeron®, or compatible processor, 233 MHz. (Pentium III 300 MHz or higher recommended)
RAM
128 MB RAM(256 MB or higher recommended)
Free disk space
650 MB
Browser
Internet Explorer 6 or later
Video display
SVGA 800 x 600 monitor with 16-bit color (32-bit color recommended)
Connectivity
Hi-Speed USB 2.0
Windows Vista 32- and 64-bit
Processor
A modern 800 MHz 32-bit (x86) or 64-bit (x64) Processor (1 GHz or higher recommended)
RAM
512 MB RAM (1 GB or higher recommended)
Free disk space
920 MB
Browser
Video display
Connectivity
Hi-Speed USB 2.0
Macintosh
Supported Macintosh operating systems: Mac OS X v10.4, v10.5, v10.6, and v10.7.
Component
Recommended system requirement
Processor
Mac OS X 10.4, 10.5, and 10.6
PowerPC with G3, G4, G5, or Intel Core Duo processor
OS X 10.7
Intel Core 2 Duo processor
Intel Core 2 Duo or higher processor
Memory
256 MB
512 MB or higher
OS X 10.7
2 GB
2 GB or higher
Browser
Any browser
Free disk space
500 MB
800 MB or higher
Connectivity USB
Hi-Speed USB 2.0
Other
CD-ROM or DVD-ROM drive
Adobe Acrobat Reader 5.0 or later (recommended)
Quick Time 5.0 or later (recommended)
Internet access (recommended)
Physical dimensions
Dimension
Measurement
Height
158.7 mm (6.25 inches)
Width
419.1 mm (16.5 inches)
Depth
266.7 mm (10.5 inches)
4.6 kg (10.2 lb.)
Cartridges
Americas and Asia Pacific (excluding China, India, and Japan)
Western Europe
Africa, CIS, Japan, and Middle East
China and India
Ink cartridge
HP 60
HP 300
HP 121
HP 818
Visit HP SureSupply to check ink or toner cartridge compatibility, or purchase replacement cartridges.
  1. Scroll to the bottom of the page, and then make sure the country/region location is correct.
  2. Follow the on-screen instructions to order new cartridges or check cartridge compatibility with your printer.
You can also purchase genuine HP cartridges from other retailers.
Paper types and sizes
Review the following tables for paper types and sizes.
Paper: (plain, inkjet, photo, glossy)
Paper type
Paper size
U.S. Letter
216 x 279 mm (8.5 x 11 inches)
Legal
216 x 356 mm (8.5 x 14 inches)
Executive
184 x 267 mm (7.24 x 10.51 inches)
Cabinet
127 x 177.8 mm (5 x 7 inches)
Mutsugiri
203.2 x 254 mm (8 x 10 inches)
A4
210 x 297 mm (8.27 x 11.69 inches)
A5
148 x 210 mm (5.83 x 8.27 inches)
Envelopes
Paper type
Paper size
US No.10
105 x 241 mm (4.12 x 9.5 inches)
A2 invitation
111 x 146 mm (4.37 x 5.75 inches)
DL
110 x 220 mm (4.33 x 8.66 inches)
C6
114 x 162 mm (4.49 x 6.38 inches)
Transparencies
Paper type
Paper size
U.S. Letter
A4
Labels
Paper type
Paper size
U.S. letter
A4
Cards
Paper type
Paper size
Index
76.2 x 127 mm (3 x 5 inches)
Index
101.6 x 152 mm (4 x 6 inches)
Index
127 x 203.2 mm (5 x 8 inches)
A6
105 x 148.5 mm (4.12 x 5.85 inches)
Paper type
Paper size
Photo paper
100 x 150 mm (3.94 x 5.91 inches) (tab)
130 x 180 mm (5.12 x 7.01 inches)
Photo card
101.6 x 203.2 mm (4 x 8 inches) (tab)
100 x 200 mm (3.94 x 7.87 inches) (tab)
Borderless panorama
101.6 x 254 (4 x 10 inches), 101.6 x 304.8 mm (4 x 12 inches)
100 x 250 mm (3.94 x 9.84 inches), 100 x 300 mm (3.94 x 11.81 inches)
User Defined
  1. Width: 77 mm to 216 mm (3 inches to 8.5 inches)
  2. Length: 127mm to 356 mm (5 inches to 14 inches)
Printing specifications
Review the following tables for print speed.
Paper type
Fast Draft
Black text, plain paper
Up to 20 pages per minute (ppm) after first page
Color
Up to 16 ppm after first page
Copy specifications
 Uwaga:
If you use the HP Deskjet F2420 All-in-One printer, the product must be connected to your computer to copy.
Review the following information for copy specifications.
  • Digital image processing
  • Maximum number of copies varies by model
  • Copy speeds vary according to the complexity of the document and model
  • Maximum copy enlargement ranging from 200 to 400% (varies by model)
  • Maximum copy reduction ranging from 25 to 50% (varies by model)
 Uwaga:
Copy enlargement and reduction functionality is available only on some models.
Scanning specifications
Review the following information for scanning specifications.
  • Image editor included
  • Twain-compliant software interface
  • Resolution: up to 1200 x 2400 ppi optical, depending on model (HP Deskjet F2420/2423 models up to 1200 x 1200 ppi)
  • Color: 48-bit color, 8-bit grayscale (256 levels of gray)
  • Maximum scan size from glass: 216 x 297 mm (8.5 x 11.7 inches)
Power specifications
Review the following information for input voltage.
Region
Voltage
Frequency
WW
100-240 VAC +/- 10%
50/60 Hz +/- 3 Hz
India/China
200-240 VAC +/- 10%
50/60 Hz +/- 3 Hz
Environmental specifications
Review the following information for environmental specifications.
Recommended operating conditions
Factor
Temperature
59 to 90° F; 15 to 32° C
Humidity
15 to 80% RH non-condensing
Maximum operating conditions
Factor
Temperature
41 to 104° F; 5 to 40° C
Humidity
Energy usage drops significantly while in ENERGY STAR mode, which saves natural resources, and saves money without affecting the high performance of this product. This product qualifies for ENERGY STAR, which is a voluntary program established to encourage the development of energy-efficient office products.
Rys. : Energy Star
ENERGY STAR is a U.S. registered mark of the U.S. EPA. As an ENERGY STAR partner, Hewlett-Packard Company has determined that this product meets the ENERGY STAR guidelines for energy efficiency. For more information, go to www.energystar.gov.
Material safety data sheets
Click here to get the Material safety data sheets (MSDS).
This product is suited for the use of recycled paper according to DIN 19309. Plastic parts over 25 grams are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of the product's life.
Recycling program
HP offers an increasing number of product return and recycling programs in many countries/regions and partners with some of the largest electronic recycling centers throughout the world. HP conserves resources by reselling some of its most popular products. More information on HP's recycling programs is available from the HP Web site.
Działania
Trwa ładowanie...
Spytaj społeczność!
Forum pomocy technicznej
Działania
Trwa ładowanie...
Działania
Trwa ładowanie...
Kraj: Flag Polska
Działania
Trwa ładowanie...
