Pomoc techniczna HP dla klientów
Działania
Trwa ładowanie...
Działania
Trwa ładowanie...
Działania
Trwa ładowanie...
Printer Specifications for HP Officejet 4400, Deskjet Ink Advantage (K209), Deskjet F4400 and F4500 All-in-One Printer Series
Product specifications
This document contains specifications for the product, including model numbers, system requirements, and print speed.
Models
All-in-One Model
Product Number
HP Deskjet F4435 All-in-One Printer
CB750A
HP Deskjet F4440 All-in-One Printer
CB747A
HP Deskjet F4450 All-in-One Printer
CB746A
HP Deskjet F4470 All-in-One Printer
CB751B
HP Deskjet F4472 All-in-One Printer
CB752B
HP Deskjet F4473 All-in-One Printer
CB752C
HP Deskjet F4480 All-in-One Printer
CB745A
CB745B
HP Deskjet F4483 All-in-One Printer
CB745C
CB748C
HP Deskjet F4488 All-in-One Printer
CB745D
CB748D
HP Deskjet F4492 All-in-One Printer
CB753B
HP Deskjet Ink Advantage All-in-One Printer (K209a)
CH368A
HP Deskjet Ink Advantage All-in-One Printer (K209g)
CV035A
HP Deskjet F4580 All-in-One Printer
CB755B
HP Deskjet F4583 All-in-One Printer
CB755C
HP Officejet 4400 All-in-One Printer (K410a)
CQ777A
System requirements
The following tables contain the minimum system requirements for supported Windows and Macintosh operating systems.
Windows system requirements
Supported Windows operating systems: Windows XP, Windows XP x64, Windows Vista, and Windows 7
 Uwaga:
For Windows XP x64 Edition SP 1, Windows XP SP 1 Starter Edition, and Windows Vista Starter Edition, only a basic print driver and scan driver are available.
Component
Minimum system requirement
Recommended system requirement
Processor
Windows XP Home, XP Professional, XP Media Center Edition, and Tablet PC Edition (SP2 or later)
Any Intel Pentium II, Celeron, or compatible processor, 233 MHz
Intel Pentium III (300 MHz) or higher processor
Windows XP Professional x64 Edition (basic print and scan driver only)
Any AMD Athlon 64, AMD Opteron, Intel Xeon with Intel EM64T support, Intel Pentium 4 with Intel EM64T support processor
Windows Vista
800 MHz 32-bit (x86) or 64-bit (x64) processor
1 GHz 32-bit (x86) or 64-bit (x64) processor
Windows 7
1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
RAM
128 MB
256 MB
256 MB
512 MB
Windows Vista
512 MB
1 GB
Windows 7
1 GB RAM (32-bit) or 2 GB RAM (64-bit)
Free disk space
Windows XP
650 MB
Windows Vista
1.2 GB
Windows 7
1.2 GB
Browser
Microsoft Internet Explorer 6.0 or later
Other
CD-ROM or DVD-ROM drive
Available USB port and USB cable
Networking and wireless features require a working network environment (Ethernet or 802.11b/g/n wireless depending on the HP product) for HP products with networking capability
Adobe Acrobat Reader 5 or later (recommended)
Adobe Flash Player 10 or higher
SVGA 800 x 600 monitor with 16-bit color (32-bit color recommended)
Internet access (recommended)
 Uwaga:
A USB cable can be purchased from any reputable dealer.
Macintosh system requirements
Supported operating systems: Mac OS X v10.4, v10.5, v10.6, v10.7, and v10.8.
Component
Processor
Mac OS X 10.4, 10.5, and 10.6
PowerPC with G3, G4, G5, or Intel Core Duo processor
OS X 10.7 and 10.8
Intel Core 2 Duo processor
Intel Core 2 Duo or higher processor
Memory
256 MB
512 MB or higher
OS X 10.7 and 10.8
2 GB
2 GB or higher
Browser
Any browser
Free disk space
500 MB
800 MB or higher
Other
 Uwaga:
Wireless system requirements (HP Deskjet F4500 All-in-One printer series only)
Component
Wireless network
A wireless 802.11 network that includes a WPS-enabled wireless router or access point
Computer
Wireless networking support or a network interface card (NIC).
To configure the product on the wireless network, you must connect the computer to the same wireless network.
Features and capabilities
Component
Specification
Connectivity
USB support
USB 2.0 high speed
Network support
HP Deskjet F4400 All-in-One printer series and HP Deskjet Ink Advantage K209a All-in-One Printer
None
802.11 Wireless
Font support
TrueType or OpenType fonts
Physical dimensions
Dimension
Measurement
Height
162.5 mm (6.4 inches)
Width
436.8 mm (17.2 inches)
Depth (with output tray extended)
558.8 mm (22 inches)
5.27 kg (11 lb.)
Cartridges
Americas and Asia Pacific (excluding China, India, and Japan)
Western Europe
Africa, CIS, Japan, and Middle East
China and India
Ink cartridge
HP 60
HP 300
HP 121
HP 818
Visit HP SureSupply to check ink or toner cartridge compatibility, or purchase replacement cartridges.
  1. Scroll to the bottom of the page, and then make sure the country/region location is correct.
  2. Follow the on-screen instructions to order new cartridges or check cartridge compatibility with your printer.
You can also purchase genuine HP cartridges from other retailers.
Paper handling specifications
Review the following tables for specifications regarding paper handling.
Paper tray capacities
Paper type
Paper weight
Paper tray
Plain paper
60 to 90 g/m2 (16 to 24 lb)
Up to 80 sheets (70 g/m2 [20 lb])
Cards
200 g/m2 (110 lb) index max
Up to 30
Envelopes
75 to 90 g/m2 (20 to 24 lb)
Up to 10
Photo paper
Up to 280 g/m2 (75 lb)
Up to 30
 Uwaga:
The output tray capacity varies depending on the type of paper and the amount of ink on the printout. HP recommends emptying the output tray frequently.
Supported standard paper sizes
Paper type
Paper size
U.S. Letter
216 x 279 mm (8.5 x 11 inches)
Legal
216 x 356 mm (8.5 x 14 inches)
Executive
184 x 267 mm (7.24 x 10.51 inches)
A4
210 x 297 mm (8.27 x 11.69 inches)
Supported envelopes
Envelope type
Paper size
U.S. #10 Envelope
105 x 241 mm (4.12 x 9.5 inches)
Envelope Monarch
91.44 x 190.5 mm (3.9 x 7.5 inches)
Card Envelope
111.76 x 152.4 mm (4.4 x 6 inches)
Supported cards
Card type
Paper size
Index card
76.2 x 127 mm (3 x 5 inches)
Index card
102 x 152 mm (4 x 6 inches)
Index card
127 x 203 mm (5 x 8 inches)
Supported photo paper
Photo paper type
Paper size
Photo paper
Photo paper (tab)
Photo card
101.6 x 203.2 mm (4 x 8 inches)
Photo paper
127 x 178 mm (5 x 7 inches)
Photo paper
203 x 254 mm (8 x 10 inches)
Matsugiri 8 x 10
Photo L
89 x 127 mm (3.5 x 5 inches)
Borderless photo paper
Borderless matsugiri
Borderless Photo L
Borderless 4 x 6 tab
Borderless 4 x 8 tab
Other supported paper
Paper type
Paper size
Custom-sized paper
Between 76.2 to 215.9 mm wide and 101.6 to 762 mm long (3 to 8.5 inches wide and 4 to 30 inches long)
Panorama
101.6 x 304.8 mm (4 x 12 inches)
Borderless panorama
Print margins
  • +/- 0.15 mm per mm (+/- 0.006 inch per inch) on plain paper
  • +/- 0.3 mm per mm (+/- 0.0012 inch per inch) on transparency and envelopes
Printing specifications
  • Print method: Drop-on-demand thermal inkjet printing
  • Device language: PCL3 GUI
  • Duty cycle: Up to 3000 pages per month
  • Print speed (varies by model): In pages per minute (ppm)
    • Black: Up to 28 ppm
    • Color: Up to 22 ppm
Copying specifications
  • Digital image processing
  • Up to 9 copies from original (varies by model)
  • Copy speeds vary according to the complexity of the document
  • Maximum copy enlargement ranging from 200-400% (depending on model)
  • Maximum copy reduction ranging from 25-50% (depending on model)
Scanning specifications
  • Image editor included
  • Twain-compliant interface
  • Resolution: up to 1200 x 2400 ppi optical, up to 19200 ppi enhanced (software)
  • Color: 48-bit color, 8-bit grayscale (256 levels of gray)
  • Maximum scan size from glass: 216 x 297 mm (8.5 x 11.7 inches)
Power specifications
  • Power consumption: 20 watts (average printing)
  • Input voltage: AC 100 to 240 V ~ 1 A 50–60 Hz
  • Output voltage: DC 32 V===375 mA, 16 V===500mA
  • Power supply: AC 100 to 240 V ~ 1 A 50–60 Hz (±3 Hz)
Environmental specifications
Review the following sections for environmental specifications.
Operating environment
  • Recommended operating temperature range: 15º to 32º C (59º to 90º F)
  • Allowable operating temperature range: 5º to 40º C (41º to 104º F)
  • Recommended relative humidity: 15% to 80% RH non-condensing, 28º C (82.4º F) maximum dewpoint
Storage environment
  • Non-operating (Storage) temperature range: -40º to 60º C (-40º to 140º F)
 Uwaga:
In the presence of high electromagnetic fields, it is possible that the output from the HP product might be slightly distorted.
HP recommends using a USB cable less than or equal to 3 m (10 feet) in length to minimize injected noise due to potential high electromagnetic fields.
This product is designed to reduce power consumption and save natural resources without compromising product performance. It has been designed to reduce total energy consumption both during operation and when the device is not active. This product qualifies for ENERGY STAR®, which is a voluntary program established to encourage the development of energy-efficient office products.
Rys. : Energy Star logo
ENERGY STAR is a U.S. registered service mark of the U.S. EPA. As an ENERGY STAR partner, HP has determined that this product meets ENERGY STAR guidelines for energy efficiency.
For more information, go to the Energy Star Web site (in English).
To view Material Safety Data Sheets (MSDS), go to http://www.hp.com/go/msds (in English).
This product generates no appreciable ozone gas (O3).
This product is suited for the use of recycled paper according to DIN 19309 and EN 12281:2002. Plastic parts over 25 grams (0.88 ounces) are marked according to international standards that enhance the ability to identify plastics for recycling purposes at the end of product life.
HP offers an increasing number of product return and recycling programs in many countries and regions, and partners with some of the largest electronic recycling centers throughout the world. HP conserves resources by reselling some of its most popular products. For more information about the recycling of HP products, go to www.hp.com/hpinfo/globalcitizenship/environment/recycle/ (in English).
Regulatory model number
For regulatory identification purposes, your product is assigned a Regulatory Model Number. The Regulatory Model Number for your product is SNPRH-0801. This regulatory number should not be confused with the marketing name (HP Deskjet F4400 All-in-One series, etc.) or product numbers (CB 745A-D, etc.).
Działania
Trwa ładowanie...
Spytaj społeczność!
Forum pomocy technicznej
Działania
Trwa ładowanie...
Działania
Trwa ładowanie...
Kraj: Flag Polska
Działania
Trwa ładowanie...
