The Central Processing Unit (CPU) might reach 100% usage and noise might emit from the speakers while Windows Update is in process.
This issue occurs after the Out of Box Experience.
Softpaq Description
Release Notes
Download SoftPaq
AMD High-Definition Graphics Driver - Dali
Version: 27.20.15002.118
Revision: B |
הערה:A more recent version of this software may be available. Check for updated drivers and software for your computer at http://www.hp.com/.In order to complete the driver update, keep the AC power adapter connected to the computer, and wait for the update process to complete. The firmware update will close automatically when completed.
