The fan control feature does not work in the OMEN Command Center. The issue occurs after the BIOS is updated to version F.02. When the fan speed is changed, the fan does not respond, and continues to run at the current speed.
SoftPaq Description
Release Notes
Download SoftPaq
HP Notebook System BIOS Update (Intel Processors)
Version: F.05
Revision: A |
ملاحظة:A more recent version of this software may be available. Check for newer versions at the HP Software and Drivers page.
